Retired Products
Retired Products
Multi-Tool - Luminous. Limitless. Max power.
  • Ideal for working on any material, soft or hard
  • Carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning. A constant stream of different projects you can tackle
  • Get the best results with the LED light at the front of the tool. Work with the greatest precision, even in dark areas
150 GBP
Endless possibilities - one tool. From sanding to grinding, and routing to cutting; this Multi-Tool produces power from job to job. Electronic feedback gives additional power when needed to maintain maximum performance when working with both soft and hard materials. You are always in perfect control of your projects. Even when working in awkward angles, tight spaces and dark areas. The 360° adjustable LED light at the front of the tool allows you to clearly see everything that you’re doing, so you can work with the greatest precision. Simply insert any accessory that fits your project and you’re ready to go.
With a fully adjustable 360° LED light you can complete your tasks in those difficult corners and dark areas with full visibility.
The soft and secure grip reduces vibrations to allow you to work for longer and with greater manoeuvrability.
Improved fan design means a quieter and cooler environment while you are completing your projects.
Rated power input
Voltage
Weight
0.66 kg
24 cm
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Battery technology
Speed setting
Fully Variable
Accessory quick change system
Multi Chuck
Sound pressure
74,4 dB(A)
Sound power
85,4 dB(A)
Vibration
18 m/s²
8710364079605
F0134300JB
User Manuals
Dremel 4300 with 3 attachments, 45 accessories and tool Holder in front of a black plastc case
Delivery details
  • Dremel 4300
  • 45 high quality Dremel accessories
  • Flexible Shaft (225)
  • Cutting guide (565)
  • Line & Circle Cutter (678)
  • Spacious and sturdy storage case with a removable accessory tray
  • Pivot Light
  • Sanding / Grinding Guide
  • Product box length, 39.2 cm
  • Product box height, 10 cm
  • Product box width, 26.6 cm
  • Gross weight, 2.73 kg
150 GBP
