Sanding
DREMEL® 770B-02 (770B-02)
Sanding
Versatile sanding band kit for shaping, smoothing, and rust removal.
- Boost your DIY capabilities with 48 sanding bands in 3 grits (60, 120, 240), designed for a variety of applications.
- Includes 2 mandrels for easy and secure band attachment, adding convenience to your projects.
- Ideal for rough shaping and fine finishing, these bands handle wood, fiberglass, plastics, aluminum, and steel with ease.
The Dremel 770B-01 Variety Kit expands your Multi-Tool’s potential, turning it into a precision sanding machine. Whether you're crafting, repairing, or finishing, this kit ensures you're equipped for every stage of your project.
What can you do with it?
Effortlessly shape and smooth wood, fiberglass, rubber, and plastics. Remove rust from steel or achieve detailed, polished finishes on your projects. With three grit levels, you can switch between rough shaping and fine finishing for a professional result every time. • 2 x 407 Sanding Band 6,4 mm (60 Grit) including mandrel – For aggressive material removal. • 14 x 408 Sanding Band 6,4 mm (60 Grit) – Ideal for quick debris and finish removal. • 16 x 432 Sanding Band 6,4 mm (120 Grit) – Perfect for pre-finishing wood or cleaning surfaces. • 16 x 445 Sanding Band 6,4 mm (240 Grit) – Excellent for fine sanding and detailed touch-ups on wood or varnish.
How to use.
Slide the sanding band onto a 407 Sanding Drum Mandrel and attach it to your Dremel rotary tool. Let the tool do the work without applying excessive force. Adjust the RPM based on the material for the best results. Test your technique on scrap material before diving into your project for optimal precision.
Recommended speed (RPM).
• Hardwood & Softwood: 20.000 – 30.000 • Plastic: 15.000 – 20.000 • Aluminum & Steel: 15.000 – 25.000
- Versatile sanding band kit for shaping, smoothing, and rust removal.
Sanding Band & Mandrel 6,4 mm 60 grit (430) 2 pieces
- Small sanding mandrel and sanding band (Grit P60)
Sanding Band 6,4 mm 60 grit (431) 6 pieces
- Small sanding band for detailed sanding of wood and plastics
- 2x 407 Sanding Band 6,4 mm (60 Grit) incl mandrel
- 14x 408 Sanding Band 6,4 mm (60 Grit)
- 16x 432 Sanding Band 6,4 mm (120 Grit)
- 16x 445 Sanding Band 6,4 mm (240 Grit)
