Cordless Tools
DREMEL® 7750 (7750-10)
Multi-Tool – Cordless. Precise. Easy-to-use.
A perfect finish on all of your light duty DIY projects
Sand, cut, grind, sharpen, polish, clean and engrave. One system, thousands of projects.
Free of cords - complete your indoor and outdoor projects easily
Comfortably get into tight corners and awkward spaces
2 year warranty
The cordless Dremel 4.8V with its go anywhere convenience, can easily be used indoor as well as outdoor. This tool has the ideal performance for small craft projects and light DIY tasks. Together with its comfortable handling and ease of use it’s a great tool to have ready to go at any time for sanding, cleaning and polishing or grinding and more in all kind of materials.
Technical details for DREMEL® 7750 (7750-10)
Technical specifications
Battery voltage
4,8 V
Battery capacity
1,5 Ah
Charging time
1 h
Weight
0,420 kg
21.5 cm
No load speed
8.000 - 20.000 1/min
No load speed (3)
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Vibration
5,2 m/s²
Included Accessories (11)
Delivery details: DREMEL® 7750 (7750-10)
Dremel 7750
10 high quality Dremel accessories
1-Hour battery charger
Instruction manual
Product box length, 15.6 cm
Product box height, 24.9 cm
Product box width, 7.9 cm
Gross weight, 0,95 kg
F0137750JB
8710364078530
8710364078530
