Cordless Tools
Multi-Tool – Cordless. Versatile. Always ready.
Take on any precision DIY project by simply swapping the accessory. Cut, rout, grind, sharpen, polish, clean, carve and engrave
Cordless – a perfect finish for your DIY projects always at hand, indoor and outdoor
The perfect Multi-Tool for periodic use
EZ twist - easily switch between applications in projects
2 year warranty
Technical details for DREMEL® 8100 (8100-1/15)
Technical specifications
Battery voltage
7,2 V
Battery capacity
1,3 Ah
Charging time
1 h
Weight
0,413 kg
22 cm
3.5 cm
Depth
5.5 cm
No load speed
5.000 - 33.000 1/min
Battery technology
Lithium-Ion / ECP
No load speed (3)
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Vibration
12,4 m/s²
Included accessories (15)
Delivery details: DREMEL® 8100 (8100-1/15)
Dremel 8100
15 high quality Dremel accessories
Detailer's Grip attachment (577)
1-Hour battery charger
Instruction manual
Soft bag
Product box length, 25.8 cm
Product box height, 28.7 cm
Product box width, 8.8 cm
Gross weight, 1,46 kg
F0138100JB
8710364065714
8710364065714
