Multi-Tools
Multi-Tools
Small tool, big utility.
- USB-C rechargeable 7.2V brushless battery for ultimate portability.
- Compact for comfort but powerful enough for cutting, sanding, and more.
- Integrated LED nose cap light that illuminates your work area.
Dimmable LED Nose Cap:
LED Battery Gauge:
Adjustable Speed:
Brushless Motor:
USB-C Rechargeable:
Compact and Brushless
The Dremel 8150 is the ultimate compact brushless 7.2V Multi-Tool for everyday tasks. Combining power, precision, and portability, it’s the ideal tool for both creative and functional home improvement projects. Built to handle a wide range of tasks, from engraving and cutting to sanding and sharpening, the 8150 delivers unmatched flexibility and control while saving space. It’s your go-to for tackling tasks with ease.
Designed For Your Convenience
Dremel 8150 is designed with you in mind. From a lightweight design to the button placement, this portable Multi-Tool has it all. You’ll love the tool’s super easy set-up and the option to work with a LED light, placed on the nose cap, which illuminates your space and helps you tackle various detailed tasks and make hard-to-reach areas more visible.
All You Need in One Kit
The Dremel 8150 comes complete with 20 versatile accessories for engraving, sanding, cutting, grinding, a convenient USB-C charging cord for fast and easy power-ups, and a sturdy accessory case to keep everything organized.
LED nose cap which illuminates your space.
Convenient speed bar for quick and easy adjusments.
LED battery indicator for convenient charge level visibility.
User Manuals
- Multi-Tool 8150
- 20 accessories
- Product box length, 17.6 cm
- Product box height, 22.2 cm
- Product box width, 6 cm
- Gross weight, 0.77 kg
