Cordless Tools
Multi-Tool – Cordless. Fast. Maximum power.
The Multi-Tool for the more demanding DIY’er
Save storage space. One tool for cutting, routing, grinding, sharpening, polishing, cleaning, carving and engraving
Free of any cords - you can take the tool anywhere
Comes with 1 attachment and 35 accessories. Get started on your indoor and outdoor projects straight away
2 year warranty
This kit includes the high performance 8200 Li-Ion cordless Multi-Tool, with features like the EZ Twist nose cap, collet lock out function, a motor brake and a RPM bandwidth of 5.000 to 30.000. The kit includes the Detailer's Grip attachment for optimal tool control. Next to this attachment the kit includes a 1-hour battery charger and 35 original Dremel accessories including EZ SpeedClic.
Technical details for DREMEL® 8200 (8200-1/35)
Technical specifications
Battery voltage
10,8 V
Battery capacity
1,5 Ah
Charging time
1 h
Weight
0,620 kg
25 cm
Depth
6.5 cm
No load speed
5.000 - 33.000 1/min
Battery technology
Lithium-Ion / ECP
No load speed (3)
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound power
83 dB(A)
Vibration
1,1 - 5,6 m/s²
Included accessories (25)
Overview of prices and Kit content
Order number: F0138200JB
EAN Code: 8710364051748
See Kit content
Dremel 8200
35 high quality Dremel accessories
Detailer’s Grip attachment
1-Hour battery charger
Instruction manual
Soft bag
Product box length, 25.8 cm
Product box height, 28.7 cm
Product box width, 8.8 cm
Gross weight, 1,82 kg
Order number: F0138200JE
EAN Code: 8710364051779
See Kit content
Dremel 8200
45 high quality Dremel accessories
Shaping platform attachment
Line & Circle Cutter
Instruction manual
Spacious and sturdy storage case
Product box length, 26.5 cm
Product box height, 39 cm
Product box width, 10 cm
Gross weight, 2,66 kg
DREMEL® 8200 Platinum Edition (8200-5/65)
Order number: F0138200KP
EAN Code: 8710364066261
See Kit content
Dremel 8200
65 high quality Dremel accessories
2x 10.8V Battery pack (875)
Detailer's Grip attachment (577)
Line & Circle Cutter attachment (678)
Multipurpose Cutting Guide attachment (565)
Shaping Platform attachment (576)
Comfort Guard attachment (550)
Instruction manual
Product box length, 0 cm
Product box height, 0 cm
Product box width, 0 cm
Gross weight, 6,00 kg
DREMEL® 8200 (8200-20)
Order number: F0138200JK
EAN Code: 8710364072125
See Kit content
Dremel 8200
20 high quality Dremel accessories
2x 10.8V 2.0 Ah Li-Ion Battery pack (875)
Rapid charger
Soft bag
Gross weight, 1,96 kg
