Cordless Tools
Multi-Tool – Cordless. Fast. Maximum power.
Save storage space. One tool for cutting, routing, grinding, sharpening, polishing, cleaning, carving and engraving
The Multi-Tool for the more demanding DIY’er
Free of any cords - you can take the tool anywhere, indoor and outdoor
Start your versatile projects straight away with the 2 included attachments and 45 accessories
2 year warranty
This Dremel kit is the premium offer in the cordless Multi-Tool range. The high performance 8200 Li-ion cordless Multi-Tool with EZ Twist nose cap, comes in a practical carrying case which contains a 1-hour battery charger, the Shaping Platform attachment, allowing you to sand or grind perfectly at 90° and 45°, the Line & Circle Cutter attachment and 45 original Dremel accessories including EZ SpeedClic. With this supreme kit even the most demanding craftsman will be satisfied.
Technical details for DREMEL® 8200 (8200-2/45)
Technical specifications
Battery voltage
10,8 V
Battery capacity
1,5 Ah
Charging time
1 h
Weight
0,620 kg
25 cm
Depth
6.5 cm
No load speed
5.000 - 33.000 1/min
Battery technology
Lithium-Ion / ECP
No load speed (3)
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound power
83 dB(A)
Vibration
1,1 - 5,6 m/s²
Included accessories (37)
Overview of prices and Kit content
Order number: F0138200JB
EAN Code: 8710364051748
See Kit content
Dremel 8200
35 high quality Dremel accessories
Detailer’s Grip attachment
1-Hour battery charger
Instruction manual
Soft bag
Product box length, 25.8 cm
Product box height, 28.7 cm
Product box width, 8.8 cm
Gross weight, 1,82 kg
Order number: F0138200JE
EAN Code: 8710364051779
See Kit content
Dremel 8200
45 high quality Dremel accessories
Shaping platform attachment
Instruction manual
Spacious and sturdy storage case
Product box length, 26.5 cm
Product box height, 39 cm
Product box width, 10 cm
Gross weight, 2,66 kg
DREMEL® 8200 Platinum Edition (8200-5/65)
Order number: F0138200KP
EAN Code: 8710364066261
See Kit content
Dremel 8200
65 high quality Dremel accessories
2x 10.8V Battery pack (875)
Detailer's Grip attachment (577)
Line & Circle Cutter attachment (678)
Multipurpose Cutting Guide attachment (565)
Shaping Platform attachment (576)
Comfort Guard attachment (550)
Instruction manual
Product box length, 0 cm
Product box height, 0 cm
Product box width, 0 cm
Gross weight, 6,00 kg
DREMEL® 8200 (8200-20)
Order number: F0138200JK
EAN Code: 8710364072125
See Kit content
Dremel 8200
20 high quality Dremel accessories
2x 10.8V 2.0 Ah Li-Ion Battery pack (875)
Rapid charger
Soft bag
Gross weight, 1,96 kg
