Cordless Tools
DREMEL® 8200 (8200-20)
Multi-Tool – Cordless. Fast. Maximum power.
The Multi-Tool for the more demanding DIY’er
Save storage space. One tool for cutting, routing, grinding, sharpening, polishing, cleaning, carving and engraving.
Free of any cords - you can take the tool anywhere
Comes with 20 diverse accessories for many different precision DIY projects.
2 year warranty
The Dremel 8200-20 is the ideal cordless Multi-Tool kit for demanding projects. This product kit includes 2 x 10.8V 2.0Ah Li-Ion batteries and a fast charger to ensure maximum performance and minimum downtime. Featuring 20 genuine Dremel accessories, the 8200-20 is the solution when tough jobs are to be completed.
Technical details for DREMEL® 8200 (8200-20)
Technical specifications
Battery voltage
10,8 V
Battery capacity
Charging time
0.75 h
Weight
0,600 kg
25 cm
Depth
6.5 cm
No load speed
5.000 33.000 1/min
Battery technology
Lithium-Ion / ECP
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound power
83 dB(A)
Vibration
1,1 - 5,6 m/s²
Included Accessories (20)
Overview of prices and Kit content
Order number: F0138200JB
EAN Code: 8710364051748
Dremel 8200
35 high quality Dremel accessories
Detailer’s Grip attachment
1-Hour battery charger
Instruction manual
Soft bag
Product box length, 25.8 cm
Product box height, 28.7 cm
Product box width, 8.8 cm
Gross weight, 1,82 kg
Order number: F0138200JE
EAN Code: 8710364051779
Dremel 8200
45 high quality Dremel accessories
Shaping platform attachment
Line & Circle Cutter
Instruction manual
Spacious and sturdy storage case
Product box length, 26.5 cm
Product box height, 39 cm
Product box width, 10 cm
Gross weight, 2,66 kg
DREMEL® 8200 Platinum Edition (8200-5/65)
Order number: F0138200KP
EAN Code: 8710364066261
Dremel 8200
65 high quality Dremel accessories
2x 10.8V Battery pack (875)
Detailer's Grip attachment (577)
Line & Circle Cutter attachment (678)
Multipurpose Cutting Guide attachment (565)
Shaping Platform attachment (576)
Comfort Guard attachment (550)
Instruction manual
Product box length, 0 cm
Product box height, 0 cm
Product box width, 0 cm
Gross weight, 6,00 kg
Order number: F0138200JK
EAN Code: 8710364072125
Dremel 8200
20 high quality Dremel accessories
2x 10.8V 2.0 Ah Li-Ion Battery pack (875)
Rapid charger
Soft bag
Gross weight, 1,96 kg
