Retired Products
Dremel (8220-3/35X)
Dremel Expert Kit
Get 20% extra value and experience the versatility of this kit with the 35 included Dremel accessories and 3 Dremel attachments
The cordless Dremel 8220 Multi-Tool allows you to tackle any kind of DIY project, for indoor and outdoor use.
Easily go from cutting to carving to sanding to polishing and more. The added EZ SpeedClic accessories enable you to quickly change between applications.
Have total control over your project with the added Detailer’s Grip, Shaping Platform and Comfort Guard attachments.
Stay organised with the new aluminum toolbox and store your kit anytime and any place.
Take on every kind of task with the versatile Dremel Expert Kit with 20% extra value. This kit contains the cordless Dremel 8220 Multi-Tool and 35 Dremel accessories that can tackle a wide range of applications that demand power and precision, for both indoor and outdoor use. The versatility of this kit allows you to easily go from heavy-duty precision cutting to adding the finishing touch with sanding and much more. Have the utmost control of any detailed task with the three included attachments. The new and sturdy aluminum toolbox allows you to stay organised so you can start your project right where you left it in no time.
Technical details for DREMEL® 8220 (8220-3/35X)
Technical specifications
Battery voltage
Battery capacity
Charging time
1 h
Weight
25 cm
Depth
6.5 cm
No load speed
5.000 35.000 1/min
Battery technology
Lithium-Ion / ECP
Speed setting
Fully Variable
Accessory quick change system
Sound pressure
72,5 dB(A)
Sound power
83,5 dB(A)
Vibration
11,8 m/s²
Delivery details: DREMEL® 8220 (8220-3/35X)
Dremel 8220
35 high quality Dremel accessories
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
Shield attachment (550)
1x 12V Battery pack (880)
1 Hour battery charger
Sturdy Aluminum Case
Accessory information sheet
F0138220UN
8710364081493
8710364081493
