Cordless Tools
Multi-Tool - Cordless. Luminous. Max power.
The cordless Multi-Tool for the more demanding DIY’er
Tackle all carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning projects with just one tool
The most versatile cordless Multi-Tool kit: 65 accessories, 5 attachments. Store and transport your full on kit easily with the strong aluminum tool box
Clearly see everything that you’re doing. The LED light allows you to easily work in dark areas and improves precision in all of your projects.
2 year warranty
Tackle all your detailed indoor and outdoor DIY projects with just one Multi-Tool. This cordless power tool runs on a 12V lithium-ion battery and is as powerful as corded Multi-Tools. Go from cutting and grinding to sanding and polishing with the greatest precision. The LED light enhances your visibility and even allows you to work in dark areas. The motor brake stops the accessory from spinning immediately after switching off the tool. This allows you to lay it down right after use and proceed to the next step of your project. Save time on switching the interchangeable accessories with the integrated wrench in the EZ Twist nose cap. Go from coarse to fine to a perfect detailed finish.
Example of usage
Technical details for DREMEL® 8220 (8220-5/65)
Technical specifications
Battery voltage
Battery capacity
Charging time
1.5 h
Weight
25 cm
Depth
6.5 cm
Variable Speed
5.000 - 35.000 1/min
Speed setting
Fully Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound power
83,5 dB(A)
Vibration
11,8 m/s²
Included accessories (51)
Overview of prices and delivery details
Order number: F0138220JB
EAN Code: 8710364079865
£110.00
See delivery details
Dremel 8220
5 high quality Dremel accessories
1x 12V Battery pack (880)
1.5 Hour battery charger
Product box length, 33.5 cm
Product box height, 7.6 cm
Product box width, 18 cm
Order number: F0138220JG
EAN Code: 8710364079902
£139.00
Dremel 8220
45 high quality Dremel accessories
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
1.5-Hour battery charger
Spacious and sturdy storage case
Product box length, 39.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Order number: F0138820JL
EAN Code: 8710364079940
£195.00
Dremel 8220
65 high quality Dremel accessories
2x 12V Battery pack (880)
Line & Circle Cutter attachment (678)
Multipurpose Cutting Guide attachment (565)
Comfort Guard attachment (550)
Product box length, 43.6 cm
Product box height, 24 cm
Product box width, 24 cm
