Retired Products
Retired Products
Multi-Tool - Cordless. Luminous. Max power.
  • The cordless Multi-Tool for the more demanding DIY’er
  • The perfect kit to start giving all your indoor and outdoor DIY projects a perfect finish
  • Free of any cords – take the tool anywhere and tackle all your indoor and outdoor carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning projects
116.98 GBP
Tackle all your detailed indoor and outdoor DIY projects with just one Multi-Tool. This cordless power tool runs on a 12V lithium-ion battery and is as powerful as corded Multi-Tools. Go from cutting and grinding to sanding and polishing with the greatest precision. The LED light enhances your visibility and even allows you to work in dark areas. The motor brake stops the accessory from spinning immediately after switching off the tool. This allows you to lay it down right after use and proceed to the next step of your project. Save time on switching the interchangeable accessories with the integrated wrench in the EZ Twist nose cap. Go from coarse to fine to a perfect detailed finish.
Running on a 12V lithium-ion battery, this cordless power tool maintains power and performance on both your indoor and outdoor projects.
With rotary speeds varying from 5,000 to 35,000 RPM there is no limit to the tasks you can undertake. The 8220 gives you endless possibilities for your precise DIY projects.
Battery voltage
12.0 V
Battery capacity
2.0 Ah
Charging time
1.5 h
Weight
0.660 kg
25 cm
Depth
6.5 cm
No load speed
5.000 - 35.000 1/min
Battery technology
Lithium-Ion / ECP
Speed setting
Fully Variable
Accessory quick change system
Sound pressure
72,5 dB(A)
Sound power
83,5 dB(A)
Vibration
11,8 m/s²
8710364079865
F0138220JB
User Manuals
Your Selection
Dremel 8220 with a case, Dremel shaping platform attachement, Dremel comformt guard attachment, Dremel detailer's grip attachment and some  Dremel accessories
DREMEL® 8220 (8220-3/35X)
Order number: F0138220UN
EAN Code: 8710364081493
139.99 GBP
Product details
Dremel 8220 with 2 attachments and 45 accessories in front of a grey plastc case
Order number: F0138220JG
EAN Code: 8710364079902
150 GBP
Product details
Dremel 4300 with 5 attachments and 65 accessories r in front of the platinum case
Order number: F0138820JL
EAN Code: 8710364079940
£195.00*
incl. VAT
Product details
