Retired Products
DREMEL® 8220 (8220-3/35X)
Retired Products
Dremel Expert Kit
  • Get 20% extra value and experience the versatility of this kit with the 35 included Dremel accessories and 3 Dremel attachments
  • The cordless Dremel 8220 Multi-Tool allows you to tackle any kind of DIY project, for indoor and outdoor use.
  • Easily go from cutting to carving to sanding to polishing and more. The added EZ SpeedClic accessories enable you to quickly change between applications.
139.99 GBP
Take on every kind of task with the versatile Dremel Expert Kit with 20% extra value. This kit contains the cordless Dremel 8220 Multi-Tool and 35 Dremel accessories that can tackle a wide range of applications that demand power and precision, for both indoor and outdoor use. The versatility of this kit allows you to easily go from heavy-duty precision cutting to adding the finishing touch with sanding and much more. Have the utmost control of any detailed task with the three included attachments. The new and sturdy aluminum toolbox allows you to stay organised so you can start your project right where you left it in no time.
Running on a 12V lithium-ion battery, this cordless power tool maintains power and performance on both your indoor and outdoor projects.
With rotary speeds varying from 5,000 to 35,000 RPM there is no limit to the tasks you can undertake. The 8220 gives you endless possibilities for your precise DIY projects.
Battery voltage
Battery capacity
Charging time
1 h
Weight
25 cm
Depth
6.5 cm
No load speed
5.000 35.000 1/min
Battery technology
Lithium-Ion / ECP
Speed setting
Fully Variable
Accessory quick change system
Sound pressure
72,5 dB(A)
Sound power
83,5 dB(A)
Vibration
11,8 m/s²
8710364081493
F0138220UN
User Manuals
Your Selection
Dremel 8220 with 1 attachment and 15 accessories
Order number: F0138220JB
EAN Code: 8710364079865
116.98 GBP
Product details
Dremel 8220 with 2 attachments and 45 accessories in front of a grey plastc case
Order number: F0138220JG
EAN Code: 8710364079902
150 GBP
Product details
Dremel 4300 with 5 attachments and 65 accessories r in front of the platinum case
Order number: F0138820JL
EAN Code: 8710364079940
£195.00*
incl. VAT
Product details
