Multi-Tools
Multi-Tools
Brushless motor to perform, runtime to last
  • Brushless motor provides 20% more power* and cutting speed**.
  • Experience freedom of movement with our cordless design powered by a 12V, 2AH battery.
  • Compatible with all Dremel accessories and attachments.
185 GBP
All-Powerful Cordless Freedom
Get ready for a boost! With its brushless motor, the Multi-Tool 8250 gives you 20% more power and cutting speed. Powered by a 12V, 2AH battery, it's also cordless, so you can roam wherever your DIY projects take you without being tied down to an outlet. Enjoy variable speed from 5,000 to 30,000 RPM for precise control over your tasks.
Stay Informed, Stay Comfortable, Stay Efficient
Enjoy the convenience of a reinforced digital display, providing information on speed, battery life, and warning LED indicators for tool overload or excessive temperatures. Plus, its comfortable grip ensures ease of use during extended periods of work. Additionally, seamlessly change accessories with the EZ Twist™ nose cap, which features an integrated wrench for fast and easy changes, always on hand when you need it.
Compatible with all Dremel Accessories & Attachments
From delicate details to tough tasks, the Multi-Tool 8250 can handle it all. Compatible with all Dremel accessories and attachments, it offers maximum versatility for your projects.
Built to Last
Dremel 8250 is tested to withstand the most challenging Dremel applications, ensuring it can power through every project with ease. Engineered for consistent performance and excellent tool life, it's your reliable companion for any DIY task.
Jumpstart Your Projects: The Essential Kit
Introducing the Dremel 8250-5 Multi-Tool kit, equipped with 5 essential accessories to kickstart your projects. Included are 4 EZ SpeedClic cutting wheels along with the EZ SpeedClic mandrel, enabling up to 6x faster accessory changes for seamless workflow. Keep your tool and Dremel accessories organized with the provided storage bag. Plus, with the quick start guide and accessory information sheet, you'll be all set for a perfect experience with your new Dremel 8250 Multi-Tool.
Experience the advanced digital display, highlighting speed, battery life, and equipped with warning LED indicators for tool overload or excessive temperatures.
Enjoy the EZ Twist nose cap with an integrated wrench for quick and easy accessory changes.
Soft rubber grip with a comfortable texture for improved handling and enhanced comfort.
Battery voltage
12.0 V
Battery capacity
2.0 Ah
Charging time
1.05 h
Weight
0.590 kg
24.4 cm
5.4 cm
Depth
4.7 cm
No load speed
5.000 - 30.000 1/min
Battery technology
Bit holder size
3.2 mm
Speed setting
Fully Variable Speed
Accessory quick change system
Sound pressure
71 dB(A)
Sound power
79 dB(A)
Vibration
5,6 ± 1,5 m/s²
Brushless
4053423303599
F0138250JB
User Manuals
Regulatory Information
Your Selection
Related Media DREMEL® 8250
Order number: F0138250JG
EAN Code: 4053423319750
255 GBP
Product details
