£255.00*incl. VAT
Multi-Tools
Multi-Tools
Brushless Motor Cordless Multi-Tool
  • Brushless motor provides 20% more power* and cutting speed**.
  • 2x 12V, 2 Ah batteries for prolonged use so you can work anywhere.
  • Compatible with all Dremel accessories and attachments.
£255.00*
All-Powerful Cordless Freedom
Get ready for a boost! With its brushless motor, the Multi-Tool 8250 gives you 20% more power and cutting speed. Powered by a 12V, 2AH battery, it's also cordless, so you can roam wherever your DIY projects take you without being tied down to an outlet. Enjoy variable speed from 5,000 to 30,000 RPM for precise control over your tasks.
Stay Informed, Stay Comfortable, Stay Efficient
Enjoy the convenience of a reinforced digital display, providing information on speed, battery life, and warning LED indicators for tool overload or excessive temperatures. Plus, its comfortable grip ensures ease of use during extended periods of work. Additionally, seamlessly change accessories with the EZ Twist™ nose cap, which features an integrated wrench for fast and easy changes, always on hand when you need it.
Compatible with all Dremel Accessories & Attachments
From delicate details to tough tasks, the Multi-Tool 8250 can handle it all. Compatible with all Dremel accessories and attachments, it offers maximum versatility for your projects.
Built to Last
Dremel 8250 is tested to withstand the most challenging Dremel applications, ensuring it can power through every project with ease. Engineered for consistent performance and excellent tool life, it's your reliable companion for any DIY task.
Unlock the Full Potential of Your Tool
Discover versatile performance with the Dremel 8250 Platinum+ kit equipped with 2x 12V, 2Ah batteries, 5 attachments and 65 accessories for cutting, grinding, sharpening, sanding, and cleaning. Precision attachments like the Detailer’s Grip, Comfort Guard, and Shaping Platform enhance control. EZ SpeedClic accessories make changing tools up to 6x faster than standard options. The kit includes the Dremel Box, offering flexible, organised storage with adjustable dividers and two stackable boxes.
Experience the advanced digital display, highlighting speed, battery life, and equipped with warning LED indicators for tool overload or excessive temperatures.
Enjoy the EZ Twist nose cap with an integrated wrench for quick and easy accessory changes.
Soft rubber grip with a comfortable texture for improved handling and enhanced comfort.
Battery voltage
Battery capacity
Charging time
1.35 h
Weight
0,590 kg
24.4 cm
5.4 cm
Depth
4.7 cm
No load speed
5.000 30.000 1/min
Variable Speed
5.000 - 30.000 1/min
Battery technology
Speed setting
Fully Variable Speed
Accessory quick change system
Sound pressure
Vibration
± 3 m/s²
4053423319743
F0138250JF
User Manuals
Regulatory Information
Your Selection
Dremel Multi-Tool 8250 with 5 accessories
Order number: F0138250JB
EAN Code: 4053423303599
185 GBP
Product details
