Saws
Blueprint
DREMEL® Blueprint Compact Saw (CS12V-S1)
Saws
Blueprint
Effortless Quick Cuts
  • Brushless Motor that offers lasting power in a compact size.
  • 12V, 2Ah battery so you can work anywhere.
  • Integrated laser to align your cut quickly.
120 GBP
Dremel Blueprint Compact Saw
Perfect for those quick, precise cuts that can make all the difference in your DIY projects. Its compact size means it won't weigh you down, while its power can tackle a variety of materials. Whether you're revamping your living space or building something custom, the Compact Saw is the tool you need to unlock your next project.
Laser Line Visualization
Visualize your cuts before you make them with the integrated laser line guide, ensuring quality cuts and minimal material waste every time.
Great for Quick Cuts
Ideal for projects that require swift, precise cutting without the hassle.
Versatile Cutting Capabilities
Capable of cutting through wood, pipe, plastic, and more, this saw is as versatile as your project demands.
DIY-Friendly Design
More approachable than a traditional circular saw, making it perfect for beginners and pros alike.
Rechargeable 12V Power
Your convenient cordless go-to power source for all Dremel Blueprint power tools.
Dremel Blueprint System
Part of the versatile, easy-to-use DIY tool system from Dremel, designed for those who enjoy the freedom of doing more projects with fewer tools.
Laser Cutting Guide​ Visualize your cuts before you make them with the integrated laser line guide, ensuring quality cuts and minimal material waste every time.​
Bevel Adjuster​ Easily maneuver your guide to accommodate bevel cuts with or without the cutting workstation.​
Easy Clean Up​ Use the included dust port to secure your own compatible shop vac or dust collection system.​
Battery voltage
Battery capacity
Charging time
1 h
Weight
0,950 kg
30.2 cm
17.2 cm
Depth
12.8 cm
No load speed
0 5.000 1/min
Battery technology
Cutting depth at 0°
25.4 mm
Cutting depth at 45°
15.9 mm
Blade dimension
85 mm
Blade thickness
1.5 mm max
Blade location
left
Speed setting
Variable speed
Sound pressure
90 dB(A)
Sound power
98 dB(A)
Vibration
1,67 m/s²
Brushless
4053423304206
F013CS12JB
User Manuals
Regulatory Information
Dremel Blueprint Compact Saw with attachments and Blueprint logo
Delivery details
  • CS12V Compact Saw
  • 12V, 2.0Ah Battery
  • Dremel Fast Charger
  • 1x Multi-material blade, 85mm
  • Edge Guide
  • Dust Port Adaptor
  • Allen key
  • Instruction Manual
  • Product box length, 32 cm
  • Product box height, 21 cm
  • Product box width, 13 cm
  • Gross weight, 1,13 kg
120 GBP
