Drills
Blueprint
DREMEL® Blueprint Multi-Drill (DD12V-S1)
Drills
Blueprint
Three project tools in one compact, user-friendly drill.
- Brushless Motor offering lasting power in a compact size.
- Self-adhesive line laser with 2-way bubble level.
- Integrated stud finder to conveniently locate studs in walls.
Dremel Blueprint Multi-Drill
Designed to make DIY tasks easier with its drill base, this convenient compact tool also includes a built-in stud finder, detachable laser with a bubble level. Ergonomically designed, the Dremel Blueprint Multi-Drill is easy to use, making it perfect for hanging gallery walls, mounting shelves, or fixing things around home.
Compact 12V Drill
Tackle hanging, mounting, and fastening projects small and large with 12V brushless power.
Detachable Line Laser with 2-way Bubble Level
Easily align your projects again and again with the detachable laser and reusable mounting putty. Whether you're hanging artwork or setting up a gallery wall, the laser guides you every step of the way. For those seeking perfection, our detachable line laser has a bubble level ensuring everything you install is straight.
Built-in Stud Finder
Never guess where to drill. The built-in stud finder makes it easier than ever to hang gallery walls, mount shelves, or install TVs.
Rechargeable 12V Power
Your convenient cordless go-to power source for Dremel Blueprint power tools.
Dremel Blueprint System
Part of the versatile, easy-to-use DIY tool system from Dremel, designed for those who enjoy the freedom of doing more projects with fewer tools.
X Marks the Spot Keep décor secure. Find studs with our integrated detectors. Turn the tool, calibrate, move and mark!
Laser Focused Align your projects over and over again with the detachable laser. Use your level room to room with reusable wall putty.
Stay Ready The LED battery gauge keeps you in the know when its time to charge up.
User Manuals
Regulatory Information
- Dremel Blueprint Multi-Drill
- 12V, 2.0Ah battery
- Dremel Fast Charger
- Multi-material drill bit
- 9pc drive bits
- USB-C cable
- 6pc adhesive tape
- Product box length, 25.5 cm
- Product box height, 15.5 cm
- Product box width, 12 cm
- Gross weight, 0.85 kg
