Saws
DREMEL® Blueprint Multi-Material blade (CS600)
Saws
Multi-Material Cutting Made Simple
- Effortlessly cuts wood, laminate, plastic, and non-ferrous metals.
- Designed for Dremel Blueprint Portable Saw Station and Compact Saw.
- Carbide tips provide clean, long-lasting cuts.
Multi-Material Saw Blade
Effortlessly cut through wood, laminate, plastic, and even non-ferrous metals (aluminium and copper). Our Multi-Material Saw Blade is designed to handle a variety of materials with precision and ease, transforming your Dremel Blueprint Portable Saw Station or Compact Saw into a project chameleon.
Versatility for Every Project
Engineered to seamlessly cut through wood, laminate, plastic, and non-ferrous metal. No matter the project, this blade is your go-to solution for a smooth, hassle-free cutting experience.
Blueprint Compatibility
Designed specifically for the Dremel Blueprint Portable Saw Station and Compact Saw, this blade fits perfectly, ensuring optimal performance. The seamless integration means you can focus on your project rather than worrying about compatibility issues.
Carbide for Clean Cuts
Equipped with carbide tips, this blade ensures clean, precise cuts every time. The durability of the carbide not only extends the blade's lifespan but also maintains its sharpness.
- Multi-Material Cutting Made Simple
DREMEL® Blueprint wood blade (CS500)
- Your go-to for wood cutting
DREMEL® Blueprint wood fine finish blade (CS900)
- Your go to blade for smooth, clean, fine finish wood cuts.
DREMEL® Moto-Saw Side Cutting Saw Blade (MS50) 5 pieces
DREMEL® Moto-Saw General Purpose Wood Cutting Saw Blade (MS51) 5 pieces
DREMEL® Moto-Saw Fine Wood Cutting Saw Blade (MS52) 5 pieces
DREMEL® Moto-Saw Metal Cutting Saw Blade (MS53) 5 pieces
Suitable Dremel devices
Saws
- Product box length, 5 cm
- Product box height, 155 cm
- Product box width, 115 cm
- Gross weight, 0.07 kg
