Saws
Blueprint
DREMEL® Blueprint Portable Saw Station (CS12V-SC1)
Saws
Blueprint
Tackle cuts with confidence
- 12V Brushless Compact saw with an integrated laser guide.
- Compact multi-functional saw station case with a built-in guided track for perfect straight, miter and bevel cuts.
- Contains a range of attachments and guides for best cutting experience.
Dremel Blueprint Portable Saw Station
A must-have for both homeowners, and renters alike. Designed to be compact yet powerful, this saw station fits perfectly in any home without sacrificing functionality. Its intuitive design and included accessories means you can jump right into your projects without a steep learning curve. Whether you're working on installing trim, vinyl flooring, or taking on a feature wall, this versatile saw can handle it all. From miter and bevel cuts to straight and rip cuts, the Blueprint Portable Saw Station is built to make every common cut simple.
Effortless Cutting
Make miter, bevel, straight, and rip cuts with ease for all your DIY projects. The Portable Saw Station helps you tackle similar cuts to a traditional miter and circular saw. Cut the most common DIY project materials like trim, wood and vinyl flooring.
Perfect for Small Spaces
Ideal for homeowners, renters, and DIY enthusiasts who need a versatile saw that doesn’t take up much room. The Portable Saw Station easily folds to fit in tight spaces like closets, garages, or under beds.
All-inclusive Support
Comes with cutting guides, material supports, and clamps to make your projects smoother and more manageable.
Rechargeable 12V Power
Your convenient cordless go-to power source for all Dremel Blueprint power tools.
See Cuts Clearly
Visualize your cuts instantly with our integrated alignment laser. This handy feature ensures you get a quality cut every time, minimizing errors and maximizing efficiency.
DIY Project Partner
Designed to handle all your home decor tasks like feature walls, new trim, custom frames and more.
Dremel Blueprint System
Part of the versatile, easy-to-use DIY tool system from Dremel, designed for those who enjoy the freedom of doing more projects with fewer tools.
4in1 Cutting Solution Skip the traditional miter and table saws to make miter, bevel, straight, and rip cuts with ease.
DIY Dream Designed to handle all home decor tasks like feature walls, new trim, custom frames and more.
Take the Stress out of Straight Cuts Enhance your accuracy and confidence with the laser alignment feature .
User Manuals
Regulatory Information
- Saw Station Work Case
- CS12V Compact Saw
- 12V, 2Ah Battery
- Dremel Fast Charger
- 1x Multi-material blade, 85mm
- Edge Guide
- Dust Port Adaptor
- Allen Key
- Bevel Risers, Clamp (qty 2), Board Support
- Instruction Manual
- Product box length, 18.6 cm
- Product box height, 45 cm
- Product box width, 40 cm
- Gross weight, 7.21 kg
