Blueprint
Oscillating tools
DREMEL® Blueprint Project Multi-Tool (MM12V-S1)
Blueprint
Oscillating tools
The Mightiest of Multi-taskers
  • 12V Cordless Project Multi-Tool that lets you cut, scrape, sand and remove grout with just a quick blade swap.
  • Just select your project type and let the tool set the speed for you.
  • LED backlit display for easy use in low-light conditions.
120 GBP
The mightiest of multi-taskers
Say goodbye to multiple tools and hello to multiple projects! This ergonomic tool is a must-have for homeowners, renters, DIY enthusiasts, and furniture flippers. This multi-tasking superhero lets you switch from cutting to scraping to sanding to grout removal effortlessly with the easy accessory change system. Its brushless motor delivers longer runtime, more power, and lasting durability, while cordless freedom and reduced vibration ensure superior comfort and control on every project.
A smart technology
Hit the right balance of speed and precision thanks to tool's intuitive application selector that lets you simply choose your project type, while it automatically sets the ideal speed range for you. LED backlit display lets you easily find and select the options, even in low-light conditions. This multi-tasking tool features a battery gauge that always lets you know when your tool needs a charge.
All-Inclusive Support
The kit includes 1x 12V battery, 1 charger, 6 sanding papers, 1 sanding pad, 1 scraper, and 1 cutting blade - providing everything you need to get started on a wide range of projects right out of the box.
Multi-Platform Convenience
The tool is fully compatible with Bosch Starlock accessories and Bosch Professional 12V batteries that gives you access to a wider range of accessories and flexibility to share batteries.
Dremel Blueprint System
Part of the versatile, easy-to-use DIY tool system from Dremel, designed for those who enjoy the freedom of doing more projects with fewer tools.
Battery voltage
12.0 V
Battery capacity
2.0 Ah
Charging time
1 h
Weight
0.790 kg
30.5 cm
6 cm
Depth
9 cm
No load speed
7.000 20.000 1/min
Variable Speed
7.000 - 20.000 1/min
Battery technology
Oscillating Angle
3.2 °
Speed setting
Variable speed
Accessory quick change system
Quick Lock
Sound pressure
88 dB(A)
Sound power
96 dB(A)
Vibration
2 ± 1,5 m/s²
Brushless
4053423841060
F013CM12JB
User Manuals
Regulatory Information
Dremel Blueprint MM12V - Product image
Delivery details
  • MM12V Oscillating tool
  • 12V, 2.0Ah Battery
  • Dremel Fast Charger
  • 1x Cutting accessory
  • 1x Scraping accessory
  • 1x Sanding pad
  • 6x Sanding paper (2x60gr, 2x120gr, 2x240gr)
  • Instruction manual
  • Product box length, 35.3 cm
  • Product box height, 18.5 cm
  • Product box width, 7 cm
  • Gross weight, 1.76 kg
120 GBP
