Saws
DREMEL® Blueprint wood blade (CS500)
Saws
Your go-to for wood cutting
- Handles softwood, hardwood, and plywood with ease.
- Designed for Dremel Blueprint Portable Saw Station and Compact Saw.
- Ensures precise cuts with durable carbide tips.
Wood Blade
Your go-to for all wood cutting tasks. It’s designed to handle a range of wood types, ensuring you achieve clean, precise cuts without damaging your material. Whether you're working with softwood, hardwood, or laminate, this blade can handle it all. It’s perfect for a variety of cutting projects, from simple rip cuts to more complex bevel cuts. This means you can take on any DIY project with confidence.
Versatile Wood Cutting
Perfect for soft, hard wood and plywood cutting projects. Its ability to cut through different types of wood makes it a versatile addition to your toolkit.
Blueprint Compatibility
Designed specifically for the Dremel Blueprint Portable Saw Station and Compact Saw, this blade fits perfectly, ensuring optimal performance. The seamless integration means you can focus on your project rather than worrying about compatibility issues.
Carbide for Clean Cuts
No one likes dealing with jagged edges or split wood. Equipped with carbide tips, this blade ensures clean, precise cuts every time. The durability of the carbide not only extends the blade's lifespan but also maintains its sharpness.
- Your go-to for wood cutting
DREMEL® Blueprint Multi-Material blade (CS600)
- Multi-Material Cutting Made Simple
Suitable Dremel devices
Saws
- Product box length, 5 cm
- Product box height, 155 cm
- Product box width, 115 cm
- Gross weight, 0.06 kg
