Attachments to Sharpen
DREMEL® Chainsaw Sharpening Attachment (1453)
Sharpen your dull chainsaw fast and easy
Gain the ability to sharpen multiple, different sized chains on chainsaws with your Dremel Multi-Tool and the Chainsaw Sharpening attachment.
Get a like new chainsaw feel after sharpening the blades in a short amount of time.
Increase your chainsaws life span by having the ability to sharpen with precision and accuracy.
Quickly attach by inserting an accessory and screwing on the angle guide to the nose of your Dremel Multi-Tool.
Contents: 1x Sharpening angle guide attachment, 1x Adjustment gauge, 1x Wrench, 4x Grinding Stones 4.0 mm (453), 4.5 mm (457), 4.8 mm (454) and 5.6 mm (455), 2x Spacers, 1x Quick start guide/ manual.
£17.00*
RRP incl. VAT
What can you do with it?
Bring a dull and slow chainsaw back to life with ease using your Dremel Multi-Tool and the Chainsaw Sharpening Attachment.
Give your chainsaw a new life after quickly attaching the angle guide to your Dremel Multi-Tool and using 1 of the 4 included sharpening/ grinding stone accessories, to fit your chainsaw. Much faster and convenient when compared to traditional methods.
Give your chainsaw a new life after quickly attatching the angle guide to your Dremel Multi-Tool and using 1 of the 4 included sharpening/ grinding stone accessories, to fit your chainsaw. Much faster and convenient when compared to traditional methods.
How to use?
Choose one of the 4 included grinding stone accessories based on the space between the cutting blades of your chainsaw. The included manual provides you a guide on which accessory to use.
Insert the accessory in your Dremel Multi-Tool, tighten it and mount the attachment. Get the best results by sharpening at a 30° angle and make multipule, slow strokes on every blade until they are sharpened.
Technical details for DREMEL® Chainsaw Sharpening Attachment (1453)
Technical specifications
6 cm
Depth
Suitable Dremel devices
Multi-Tools
26151453JB
8710364082353
Similar Accessories (4)
Delivery details: DREMEL® Chainsaw Sharpening Attachment (1453)
Sharpening Angle Guide
Adjustment Gauge
Chainsaw Sharpening Grinding Stones
Spacers
Product box length, 9 cm
Product box height, 12 cm
Product box width, 4 cm
26151453JB
8710364082353
8710364082353
