Attachments to Control
DREMEL® Comfort Guard (550(1))
Clear and simple solution for redirecting debris and sparks
  • Deflects debris and sparks away without interfering with the task at hand.
  • Deflects debris for various applications, including cutting, sanding, grinding, and polishing.
  • Suitable for both right- or left-hand grip positions.
16 GBP
What can you do with it?
Sparks and debris can be a hazard when using you Multi-tool. This attachment will redirect debris and sparks away from you and create a more comfortable working environment. Comfort Guard attachment does not interfere with the workpiece due to its compact size. It is easy to adjust to your grip position. You can use this attachment for cutting, sanding, grinding, and polishing.
How to use?
Simply screw on to your Dremel Multi-Tool, find your grip position, adjust the attachment and start tackling your project.
55 cm
8710364083008
26150550JB
Comfort Guard attachment with extra accessories
Delivery details
  • Shield attachment
  • 1 mandrel SC402
  • 1 metal cutting disk SC456
  • 1 grinding stone 8193
  • 1 steel wire brush 428
16 GBP
