Printers
DREMEL® DigiLab 3D Printer 3D40 (3D40-01)
Easy-to-use 3D printer - Get started in the world of wireless 3D printing
Layer by layer the printer makes your idea turn into a high quality 3D object.
The perfect printer to place at home as well as in classrooms
3D Ecosystem - ready-to-print models, design tools, how-to's, expert support and more, all in one
Launch your prints remotely with WiFi - just press the button on your computer and your idea becomes reality
Start bringing your creative, functional or personalised ideas to life within seconds
This kit is the perfect choice for you to get started with printing 3D models, even wireless. The 3D40-01 kit includes the Dremel DigiLab 3D40 with WiFi, 1 role of white PLA filament and other items allowing you to start printing right away.
Example of usage
Technical details for DREMEL® DigiLab 3D Printer 3D40 (3D40-01)
Technical specifications
Voltage
Weight
15,88 kg
Height
40.7 cm
51.5 cm
Depth
39.8 cm
Extruder
Single Extrusion
Extruder temperature
Up to 230 ℃
Operating interface
3.5” full color IPS touch screen
Max build volume
25.4cm x 15.2cm x 17.0 cm
Layer thickness
0.1mm / 100 microns
Filament
PLA
Build platform
Tempered Glass
Internal storage
4 GB
Material diameter
1.75 mm
Filament length
162 m
Delivery details: DREMEL® DigiLab 3D Printer 3D40 (3D40-01)
Dremel® DigiLab 3D Printer 3D40
1x DREMEL® 3D Filament White (DF01)
1x USB Cable
1x USB Flash Drive
1x Power Cable
1x Object Removal Tool
3x Build Tape
1x Cleaning Tool
Product box length, 47 cm
Product box height, 47 cm
Product box width, 58.5 cm
Gross weight, 20,00 kg
F0133D40JA
8710364077595
8710364077595
