Printers
DREMEL® DigiLab 3D Printer 3D40 Build Tape (BT40-02)
During printing the Dremel 3D40 build tape fixes 3D printed objects to the build plate and supports optimal printing of 3D objects. The 3D printed objects can then be easily removed from the build tape once printing is finished. Dremel 3D40 build tape can easily be attached to the build plate and can be used for several prints before being replaced. The surface area of the build tape is 15.8 (L) x 25.9 (W) cm which is an ideal size for the Dremel 3D40 Build Plate. Not compatible with Dremel 3D20 Idea Builder.
Technical details for DREMEL® DigiLab 3D Printer 3D40 Build Tape (BT40-02)
Technical specifications
260,0 mm
1,0 mm
Height
158,0 mm
Package Contents
2 pieces
Delivery details: DREMEL® DigiLab 3D Printer 3D40 Build Tape (BT40-02)
2x DREMEL® 3D40 Build Tape
Product box length, 17 cm
Product box height, 28.8 cm
Product box width, 0.3 cm
Gross weight, 0,11 kg
2615BT02JA
8710364078028
8710364078028
