Printers
DREMEL® DigiLab 3D Printer 3D40 Flex Build Tape (BT40-FLX-02)
The right support for your DigiLab 3D40 FLEX - avoid warping and ensure easy print removal
  • Help parts stick to your 3D40 FLEX Flexible Build Plate
  • Each sheet lasts up to 50 builds
  • Includes 2 3D40 FLEX Build Tapes
  • Pre-cut to fit your Dremel 3D40 FLEX Flexible Build Plate
Using a build tape on your Dremel Digilab 3D40 FLEX 3D printer helps parts stick to your 3D printer's flexible build plate when you're printing, and makes removing 3D prints easier when your prints are done. Each build sheet lasts up to 50 prints and applies easily to the build plate without the bumps or bubbles of adhesive tape. Prints come out better and the build plate is protected from print residue. These build sheets are designed specifically for the Dremel 3D40 FLEX or Dremel 3D40 with flexible build plate upgrade. Two build tapes included.
Variations
Similar Accessories (11)
Recommended products:
DREMEL® DigiLab 3D Printer 3D40 FLEX
£1,270.00* RRP incl. VAT
