Printers
DREMEL® DigiLab 3D Printer 3D45 (3D45-02)
High quality 3D printer - Bring the power of advanced FDM 3D printing to your desktop
  • The perfect printer for design creations and prototyping with a variety of filament types
  • Wifi connectivity, built-in HD camera and included Dremel DigiLab 3D slicing software to manage your prints remotely. You can also print via USB
  • Closed build area with optimised cooling and filtration system to keep out dust and avoid fumes
  • High quality 3D builds a resolution up to 50 microns which is printed on a heated bed to avoid warping
  • RFID built-in to detect the filament type (PLA, Nylon, Eco-ABS, PETG) inserted and to automatically change printer settings
£1,600.00* RRP incl. VAT
This kit is the perfect choice for creative and experimental 3D printing with ease. The 3D45-02 kit includes the Wi-Fi enabled Dremel 3D printer 3D45, 1 spool of black ECO-ABS filament and 1 spool of translucent PETG filament allowing you to start printing right away.
Example of usage
Inside of 3D45 printer and RFID filament
Enhance the possibilities of 3D printing
The DigiLab 3D45 is a 3D printer that can tackle more demanding, advanced filament types at higher temperatures like nylon, polycarbonate, PLA, and Eco-ABS — a form of ABS manufactured in an environmentally sustainable manner. With a heated bed that allows advanced types of filament, such as Eco-ABS and Nylon, the 3D45 is designed for use in higher education and experienced high school classrooms to visualise and create complex projects. Simplicity and accessibility are central to the design of the printer, with intuitive instructions and real-time analysis on the touch screen display. The new plate to heat does not need adhesive tape since it is made of tempered glass, guaranteeing a better result at the time of printing.
"Extruder" part of 3D45 printer up close
Higher quality 3D printing results
The combination of improved attributes provides the users even better 3D printing results with the same ease of use. The innovative extruder now allows a print resolution of 50 microns. Together with the added filtration system, the enclosed 3D45 prints its layers whilst remaining protected from all dust. All that while the temperature is consistently kept at an optimal level and prevents the printed object from warping thanks to the heated bed and improved cooling system. Avoiding failure prints, the 3D45 furthermore incorporates smart sensor technology, allowing effortless, accurate calibrations, and easy set-up. The touch screen shows you in real time how to precisely level the plate with just the turn of a knob.
Control panel of 3D45 printer
Stay connected with your 3D print job
With the integrated camera, users have the ability of monitoring their printing project: teachers for example can track the three-dimensional printing in real time with their students by accessing the camera's IP address. Thanks to the WLAN function, users can also start their prints remotely. To allow users to move quickly and easily from design to the printed 3D object, the DigiLab 3D45 offers the new "Dremel DigiLab 3D Slicer" software for convenient and intuitive slicing of the print file. The software is also compatible with the previous Dremel 3D40 3D printer.
Functions and Advantages of DREMEL® DigiLab 3D Printer 3D45 (3D45-02)
RFID filament recognition allows printer to automatically adjusts settings by reading the filament RFID tag
Heated bed for optimal printing results
WiFi and integrated camera for printing and monitoring your 3D object remotely
Technical details for DREMEL® DigiLab 3D Printer 3D45 (3D45-02)
Technical specifications
Voltage
Weight
19,40 kg
51.5 cm
Height
40.6 cm
39.4 cm
Extruder
Single extrusion
Extruder temperature
Up to 280 C
Operating interface
4.5" full color IPS touch
Max build volume
25.4cm x 15.2cm x 17.0cm
Layer thickness
0.05mm / 50 microns
Filament
PLA, Eco-ABS, Nylon, PETG
Build platform
Heated bed, tempered glass
Internal storage
8 GB
Material diameter
1.75 mm
Filament length
162 m
Delivery details: DREMEL® DigiLab 3D Printer 3D45 (3D45-02)
Dremel® DigiLab 3D45
1x DREMEL® 3D Eco-ABS Filament Black
1x DREMEL® 3D PETG Filament Translucent
1x USB Cable
1x USB Flashdrive
1x Unclog Tool
1x Object Removal Tool
1x Glue Stick for Printing on Heated Bed
Product box length, 58 cm
Product box height, 47 cm
Product box width, 47 cm
Gross weight, 20,00 kg
F0133D45JA
8710364080236
Recommended products:
DREMEL® DigiLab 3D Printer 3D40
£1,150.00* RRP incl. VAT
Manuals
Download User manual
