Sanding
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Detail Abrasive Brush 120 grit (472S)
Sanding
Glass fibre reinforced plastics
Sandwich material
Brass
Copper
Plywood
Softwood
Chipboard
Hardwood
Laminates
Hardened Steel
Soft Metal
Stainless Steel
Plastic
What can you do with it?
Great for detail cleaning and light sanding. Allows sanding of contours, details, and hard-to-reach areas. Built-in polishing compound - rubber bristles have abrasive inside, no need for polishing compound. Removes exterior surface layer without damage to base layer below and removes the paint but not the wood with light pressure Both abrasive brushes and buffs are available in fine, medium and coarse grades.
How to use?
Use with SC402 or 402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 and 402 sold separately). Abrasive Brushes are best used with the edge placed against the work piece, and do not require excessive pressure to see results. If the results are not strong enough, consider changing to one of the coarser brushes.
Compatible with both the Dremel Exclusive SC402 EZ Lock mandrel and standard 402 mandrel
Materials to use on
Sand and Clean wood, aluminum, plastic, metal, steel and vinyl
Recommended speed
Maximum RPM: 15.000 RPM
- Great for detail cleaning and light sanding (Grit 120).
DREMEL® EZ SpeedClic: Detail Abrasive Brush 36 grit (471S)
- Great for detail cleaning and light sanding (Grit 36).
DREMEL® EZ SpeedClic: Detail Abrasive Brush 220 grit (473S)
- Great for detail cleaning and light sanding (Grit 220).
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
