Cutting
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Diamond Cutting Wheel. (SC545)
Cutting
For limited tough cuts in materials like floor tile (but not metals)
  • Designed with the patented EZ Speedclic™ system making accessory changes 6X faster than using a standard mandrel
  • Diamond coated wheel for increased durability and low wear
  • Allows precise straight cuts with little dust
See all variations
27 GBP
Porcelain
Brick
Marble
Drywall/Plasterboard
Aerated Concrete
Granite
Ceramic
Wall Tile
Glass
What can you do with it?
For smooth, fine cuts in hard materials such as marble, concrete and brick. Designed to be long lasting (completely coated with fine diamond particles) and not lose its shape or break. Diamond disc has breathing holes for reduced heat and less debris during use.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately).
Cutting wheels only work on their edge
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits
Cuts 12.7mm (1/2") thick floor tile
Materials to use on
Hard materials, such as marble, concrete, brick, porcelain, ceramics, hard epoxy and soft and hard wood. Do not use on metals.
Recommended speed
15.000-35.000
Working diameter
Package contents
Price
2615S545JB
38.0 mm
1 piece
£26.50*
  • For limited tough cuts in materials like floor tile (but not metals)
2615S476JB
38.0 mm
5 pieces
£14.50*
DREMEL® EZ SpeedClic: Plastic Cutting Wheels. (SC476) 5 pieces
  • For making straight cuts and slots in plastics
2615S544JB
38.0 mm
1 piece
£26.50*
DREMEL® EZ SpeedClic: Wood Cutting Wheel. (SC544)
  • With carbide coating for cutting wood and laminate (Not metal)
2615S456JD
38.0 mm
12 pieces
£21.50*
DREMEL® EZ SpeedClic: Metal Cutting Wheels 12-Pack. (SC456B) 12 pieces
  • Reinforced for durability, make cuts in e.g. hardened steel
Shank diameter
3.2 mm
Working diameter
38.0 mm
Max working depth
11.0 mm
38.0 mm
Maximum RPM
35,000 1/min
38.0 mm
Height
1.0 mm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364042883
2615S545JB
Dremel accessory SC545
Delivery details
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
27 GBP
