Cutting
DREMEL® EZ SpeedClic: Diamond Cutting Wheel. (SC545)
DREMEL® EZ SpeedClic: Diamond Cutting Wheel. DREMEL® EZ SpeedClic: Diamond Cutting Wheel.
For limited tough cuts in materials like floor tile (but not metals)
£20.00* RRP incl. VAT
What can you do with it?
For smooth, fine cuts in hard materials such as marble, concrete and brick. Designed to be long lasting (completely coated with fine diamond particles) and not lose its shape or break. Diamond disc has breathing holes for reduced heat and less debris during use.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE
Cutting wheels only work on their edge
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits
Cuts 12.7mm (1/2") thick floor tile
Materials to use on
Hard materials, such as marble, concrete, brick, porcelain, ceramics, hard epoxy and soft and hard wood.
Do not use on metals.
Recommended speed
15.000-20.000
Example of usage
Technical details for DREMEL® EZ SpeedClic: Diamond Cutting Wheel. (SC545)
  • Porcelain Porcelain
  • Brick Brick
  • Marble Marble
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Granite Granite
  • Ceramic Ceramic
  • Wall Tile Wall Tile
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
Max working depth
11,0 mm
Maximum RPM
20.000 1/min
Height
1,0 mm
Package Contents
1 piece
Variations
Delivery details: DREMEL® EZ SpeedClic: Diamond Cutting Wheel. (SC545)
Product box length, 1.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615S545JB
8710364042883
