Sanding
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 180 & 280 grit (511S) 2 pieces
Sanding
For cleaning and light sanding of e.g. glass, wood, metal and plastic.
- designed with a system making accessory changes 6X faster than using a standard mandrel
- Refinish furniture, clean grills, remove paint, tarnish and more
- Compatible with all Dremel Multi-Tools
Metal pipes
Steel-general
Sandwich material
Veneered woods
Plastic
Brass
Copper
Soft Metal
Laminates
Softwood
Hardwood
Plywood
Chipboard
Fiberboard
What can you do with it?
Best for cleaning and light sanding on materials like metal, glass, wood, aluminum and plastics Available in fine, medium and coarse grades. Great to refinish furniture, clean grills, remove paint, tarnish and more
How to use?
Use with SC402 or 402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 and 402 sold separately). When using a 511S or 512S, after turning on the tool, touch the buff LIGHTLY to the material and pass over the area a few times until the material is cleaned up. A lighter touch is the best technique with this accessory. Pushing on the buff will damage it and wear it out more quickly. To extend the life of the 511S, 512S, they should not be be run in excess of 15,000 rpm
Compatible with both the Dremel Exclusive SC402 EZ Lock mandrel and standard 402 mandrel
Materials to use on and recommended speed
Aluminium 20.000 MAX Brass 20.000 MAX Copper 20.000 MAX Hardwood 20.000 MAX Plastic 20.000 MAX Softwood 20.000 MAX Steel 20.000 MAX
- For cleaning and light sanding of e.g. glass, wood, metal and plastic.
Finishing Abrasive Buffs 180 & 280 grit DREMEL® MAX EZ SpeedClic (S511DM)
DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 320 grit (512S) 2 pieces
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 3 cm
- Product box height, 10 cm
- Product box width, 5 cm
