Sanding EZ SpeedClic accessories
Dremel (511S)
DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 180 & 280 grit
DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 180 & 280 grit DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 180 & 280 grit
For cleaning and light sanding of e.g. glass, wood, metal and plastic.
£6.50* RRP incl. VAT
What can you do with it?
Best for cleaning and light sanding on materials like metal, glass, wood, aluminum and plastics
Available in fine, medium and coarse grades. Great to refinish furniture, clean grills, remove paint, tarnish and more
How to use?
Use with SC402 or 402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 and 402 sold separately).
When using a 511S or 512S, after turning on the tool, touch the buff LIGHTLY to the material and pass over the area a few times until the material is cleaned up. A lighter touch is the best technique with this accessory. Pushing on the buff will damage it and wear it out more quickly. To extend the life of the 511S, 512S, they should not be be run in excess of 15,000 rpm
Compatible with both the Dremel Exclusive SC402 EZ Lock mandrel and standard 402 mandrel
Materials to use on and recommended speed
Aluminium 20.000 MAX
Brass 20.000 MAX
Copper 20.000 MAX
Hardwood 20.000 MAX
Plastic 20.000 MAX
Softwood 20.000 MAX
Steel 20.000 MAX
Example of usage
Technical details for DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 180 & 280 grit (511S)
  • Metal pipes Metal pipes
  • Steel-general Steel-general
  • Sandwich material Sandwich material
  • Veneered woods Veneered woods
  • Plastic Plastic
  • Brass Brass
  • Copper Copper
  • Soft Metal Soft Metal
  • Laminates Laminates
  • Softwood Softwood
  • Hardwood Hardwood
  • Plywood Plywood
  • Chipboard Chipboard
  • Fiberboard Fiberboard
  • Mandrel Mandrel
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
25,0 mm
Nylon with Aluminum Oxide Abrasive
Shape
Buffs
Mandrel use
Compatible with EZ402, SC402 and 402
Grit
180 / 280
24,0 mm
Maximum RPM
20.000 1/min
24,0
Height
9,0
Variations
Delivery details: DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 180 & 280 grit (511S)
Product box length, 3 cm
Product box height, 10 cm
Product box width, 5 cm
2615S511JA
8710364037100
