Grinding / Sharpening
EZ SpeedClic accessories
DREMEL® EZ SpeedClic Grinding Wheel (SC541) 2 pieces
Reinforced wheel for grinding materials like metal
- Designed with the patented EZ Speedclic system making accessory changes 6X faster than using a standard mandrel
- The face and side of the accessory can both be used for surface and flush grinding
- Ideal for shaping, smoothing, sharpening, deburring, rust removal and general purpose edge grinding on most materials - including stainless steel
Metal pipes
Sheet Metal
Drywall/Plasterboard
Aerated Concrete
Soft Metal
Brass
Gold
Hardened Steel
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
Shaping, smoothing, sharpening, deburring, rust removal and general purpose grinding on most material.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel sold separately) The disk is designed to be used with the Dremel tool facing towards your workpiece, or also with the side of the accessory touching the project. There is an indent on the disc which allows the mandrel to not touch the workpiece when in use face down. This allows for grinding on a flat surface. An example could be grinding down a nail head.
Materials to use on:
Metal, stainless steel, aluminium, brass, ceramic, copper hardwood, plastic, softwood, stone.
Recommended speeds:
Aluminium 15000 Brass 15000 Ceramic 35000 Copper 15000 Hardwood 35000 Plastic 20-25000 Softwood 35000 Stone 20-25000
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1 cm
- Product box height, 10 cm
- Product box width, 5 cm
