Cutting
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Metal Cutting Wheels 12-Pack. (SC456B) 12 pieces
Cutting
Reinforced for durability, make cuts in e.g. hardened steel
- Cut-off Wheels are reinforced with fiberglass for increased durability to cut, trim and groove into a variety of metals including hardened steel. Ideal for easily cutting or slotting bolts, screws or sheet metal, thin wood, ceramic and plastic.
- Includes 12 fiberglass-reinforced cut-off wheels designed to last 2X longer.
- Designed with the patented EZ Speedclic™ system making accessory changes 6X faster than using a standard mandrel by eliminating the need for a screw and a screwdriver.
Metal pipes
Sheet Metal
Drywall/Plasterboard
Aerated Concrete
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
For slicing and cutting metal including hardened steel. Ideal for cutting, grooving and trimming all kinds of metal. Cut-off wheels make it easy to cut bolts or screws or make slots in rusted or stripped bolts and screws for removal with a screwdriver. Reinforced with fiberglass for increased durability. The SC409 wheels have a thickness of just 0.75 mm for even thinner cuts.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately).
Cutting wheels only work on their edge.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron or even hardened steel.
Recommended speed
Aluminium 35000 Brass 35000 Copper 35000 Steel 35000
- Reinforced for durability, make cuts in e.g. hardened steel
DREMEL® EZ SpeedClic: Starter Set. (SC406) 2 pieces
- SC Mandrel and 2 Metal Cutting Wheels. For cuts in e.g. hardened steel
DREMEL® EZ SpeedClic: Thin Cutting Wheels. (SC409) 5 pieces
- Extra thin cutting wheel. For making cuts in sheet metal and aluminium
DREMEL® EZ SpeedClic: Metal Cutting Wheels 5-Pack. (SC456) 5 pieces
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
