Sanding
DREMEL® EZ SpeedClic: Sanding Discs
DREMEL® EZ SpeedClic: Pet Nail Grooming Discs (SD60-PGK)
What can you do with it?Combined with the Dremel 7020 pet nail grooming tool these sanding discs can be used for safe and stress-free nail filing of your pet’s nails. The discs have a grit of 60, making them the perfect accessory for gradually sanding away the nail.How to use?The accessories can be attached to the EZ SpeedClic mandrel up to 6 times faster, which allows you to change accessories as quickly as pull – twist – release. By gradually sanding away the nail bit-by-bit, you are less likely to cut the quick, which causes the nail to bleed. Materials to use onUse it on your pet’s nails.
A safe and stress-free nail trimming experience for your pet.
Quickly change accessories by pulling – twisting – releasing the accessory with the EZ SpeedClic system.
The pet nail grooming sanding discs have a grit of 60, making them the perfect accessory for gradually sanding away the nail to prevent bleeding.
£12.00*
RRP incl. VAT
How to use?
Materials to use on
Technical details for DREMEL® EZ SpeedClic: Pet Nail Grooming Discs (SD60-PGK)
Technical specifications
22,0 mm
Shape
Disc
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
Sandpaper with Silicon Carbide Abrasive
Delivery details: DREMEL® EZ SpeedClic: Pet Nail Grooming Discs (SD60-PGK)
10x SD60-PGA sanding discs (Grit 60)
2615PG10AC
8710364080526
8710364080526
