Cutting
DREMEL® EZ SpeedClic: Plastic Cutting Wheels. (SC476)
DREMEL® EZ SpeedClic: Plastic Cutting Wheels. DREMEL® EZ SpeedClic: Plastic Cutting Wheels.
For making straight cuts and slots in plastics
£11.00* RRP incl. VAT
What can you do with it?
The SC476 is a reinforced cut-off wheel ideal for making clean cuts in plastics.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE
Cutting wheels only work on their edge. Plastic can melt at high RPM, so we recommend to start at low RPM and not exceed the RPM limit of 15.000 RPM.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure.
Materials to use on
Plastic materials, like vinyl and plexiglass
Recommended speed
10.000 – 15.000 RPM
Example of usage
Technical details for DREMEL® EZ SpeedClic: Plastic Cutting Wheels. (SC476)
  • Aerated Concrete Aerated Concrete
  • Drywall/Plasterboard Drywall/Plasterboard
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
Max working depth
14,0 mm
Maximum RPM
Height
1,0 mm
Package Contents
5 pieces
Variations
Delivery details: DREMEL® EZ SpeedClic: Plastic Cutting Wheels. (SC476)
Product box length, 1.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615S476JB
8710364042852
Recommended products:
EZ SpeedClic Cutting Accessory Set
£27.00* RRP incl. VAT
