Cleaning / Polishing
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Polishing Cloth Wheel. (423S)
Polish silverware to high luster and for car detailing
- Designed with a system making accessory changes 6X faster than using a standard mandrel
- Polish silverware to high luster - also great for car detailing and restoring door and window hardware
- Compatible with all Dremel Multi-Tools
4.3 GBP
Glass fibre reinforced plastics
Steel profiles
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Plastic
Plexiglass
Shank diameter
Working diameter
25.0 mm
Felt Fabric
Shape
Wheel
Mandrel use
Compatible with EZ402, SC402 and 402
24.0 mm
Maximum RPM
20,000 1/min
24.0 mm
Height
5.0 mm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364037124
2615S423JA
Order number2615S423JA
EAN Code8710364037124
Delivery details- Product box length, 2.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
4.3 GBP
