Cutting
DREMEL® EZ SpeedClic: S545DM Diamond Cutting Wheel ( SC545DM)
DREMEL® EZ SpeedClic:  S545DM Diamond Cutting Wheel DREMEL® EZ SpeedClic:  S545DM Diamond Cutting Wheel
Diamond cutting wheel for smooth, fine cuts in hard materials
  • Diamond wheel with maximum durability and lasting performance demanding cutting applications that require precision
  • Lasts 3 times longer than the regular 545 diamond cutting wheel
  • Cut in hard and abrasive materials like marble, concrete, brick, porcelain or ceramics
  • Designed with the EZ SpeedClic system making accessory changes quick and easy
  • Contents: 1x Dremel® Max EZ Speedclic Diamond Cutting Wheel (SC545DM)
£23.99* RRP incl. VAT
Be ready for your demanding and extensive DIY project with the Dremel® Max accessory line. Designed by our engineers, the accessories provide maximum durability and lasting performance. The Max Life SC545DM Diamond Wheel is engineered to last 3 times longer compared to the regular 545 wheel. The cutting wheel is completely coated with fine diamond particles to cut through hard materials.
What can you do with it?
The diamond coating adds durability and longevity, while producing smooth and precise cuts. Ideal for cutting in hard and abrasive materials like marble, concrete, brick, porcelain, ceramics, hard epoxy, and soft or hard wood. The SC545DM features a 38.1mm diameter and is designed with the exclusive EZ SpeedClic system making accessory changes quick and easy.
How to use:
Use with SC402 EZ SpeedClic Mandrel. The SC545DM features a 38.1mm diameter and is designed with the exclusive EZ SpeedClic system making accessory changes keyless, easy and fast: PULL - TWIST – RELEASE
Make cuts with the edge of the cutting wheels. We recommend using a (two-handed) golf grip when using this accessory. Let the accessory do the work without putting too much pressure on it or exceeding the maximum RPM to have the accessory last as long as possible. Are you in need to cut in a tight and awkward spaces? Use the Dremel 575 Right Angle Attachment to get into these hard-to-reach places. Cut through 12.7mm thick floor tiles.
Materials to use on:
Hard materials, such as marble, concrete, brick, porcelain, ceramics, hard epoxy and soft and hard wood. Do not use on metals.
Recommended speed (RPM):
15.000-20.000
Example of usage
Technical details for DREMEL® EZ SpeedClic: S545DM Diamond Cutting Wheel ( SC545DM)
  • Porcelain Porcelain
  • Brick Brick
  • Marble Marble
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Granite Granite
  • Ceramic Ceramic
  • Wall Tile Wall Tile
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
Max working depth
14,0 mm
Total length
38 mm
Maximum RPM
Height
1,0 mm
Dremel MAX Accessories
Dremel MAX Accessories - Maximum Durability. Lasting Performance
Get more information about the complete program.
Variations
Delivery details: DREMEL® EZ SpeedClic: S545DM Diamond Cutting Wheel ( SC545DM)
Product box length, 1.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615S545DM
8710364082742
