Sanding
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Sanding Discs (SC413) 6 pieces
Sanding
Easy to change disks for flat and edge sanding of e.g. wood
- Designed with the patented EZ Speedclic™ system making accessory changes 6X faster compared to the regular Dremel sanding discs
- Use mainly the center of the disc for maximum results.
- Easy to change disks for flat and edge sanding of e.g. wood
Sandwich material
Steel-general
Metal pipes
Veneered woods
Plastic
Brass
Copper
Softwood
Soft Metal
Fiberboard
Laminates
Plywood
Hardwood
Chipboard
What can you do with it?
Common uses for the Dremel sanding disc include smoothing and shaping wood or removing paint. is great for (smooth) flat and edge sanding of soft materials such as wood and fiberglass Dremel sanding discs have a finer grit than Dremel sanding bands. Also used for rust removal The lower the grit, the more material removal. The SC411 (grit: 60) and SC 411 (grit: 240) are from the Dremel Exclusive EZ Speedclic family. This makes accessory changes easy as PULL - TWIST - RELEASE.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately). These discs are best used with the Dremel tool facing towards the work piece, and are flexible to accommodate for any curves on the project. We recommend using mainly the center of the disc for maximum results.
Sanding discs will wear out and are replaceable by removing the mandrel.
Materials to use on
These disks can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 10-35000 Softwood 10-35000 Aluminium 35000 Brass 35000 Copper 25-35000 Plastic 10-20000
DREMEL® EZ SpeedClic: Sanding Discs (SC411) 6 pieces
Sanding Band 13 mm 120 grit (432) 6 pieces
- Large sanding band for sanding of wood and plastics
Sanding Band 6,4 mm 60 grit (431) 6 pieces
- Small sanding band for detailed sanding of wood and plastics
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.6 cm
- Product box height, 10 cm
- Product box width, 5 cm
- Gross weight, 0.01 kg
