Sanding EZ SpeedClic accessories
Dremel (SC411)
DREMEL® EZ SpeedClic: Sanding Discs
DREMEL® EZ SpeedClic: Sanding Discs DREMEL® EZ SpeedClic: Sanding Discs DREMEL® EZ SpeedClic: Sanding Discs
Easy to change disks for flat and edge sanding of e.g. wood
£5.90* RRP incl. VAT
What can you do with it?
Common uses for the Dremel sanding disc include smoothing and shaping wood or removing paint. is great for (smooth) flat and edge sanding of soft materials such as wood and fiberglass Dremel sanding discs have a finer grit than Dremel sanding bands. Also used for rust removal
The lower the grit, the more material removal.
The SC411 (grit: 60) and SC 413 (grit: 240) are from the Dremel Exclusive EZ Speedclic family. This makes accessory changes easy as PULL - TWIST - RELEASE.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately). These discs are best used with the Dremel tool facing towards the work piece, and are flexible to accommodate for any curves on the project. We recommend using mainly the center of the disc for maximum results.
Sanding discs will wear out and are replaceable by removing the mandrel.
Materials to use on
These disks can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel.
Can shape rubber surfaces
Recommended speed
Hardwood 10-35000
Softwood 10-35000
Aluminium 35000
Brass 35000
Copper 25-35000
Plastic 10-20000
Example of usage
Technical details for DREMEL® EZ SpeedClic: Sanding Discs (SC411)
  • Sandwich material Sandwich material
  • Steel-general Steel-general
  • Metal pipes Metal pipes
  • Veneered woods Veneered woods
  • Plastic Plastic
  • Brass Brass
  • Copper Copper
  • Aluminium Aluminium
  • Softwood Softwood
  • Soft Metal Soft Metal
  • Fiberboard Fiberboard
  • Laminates Laminates
  • Plywood Plywood
  • Hardwood Hardwood
  • Chipboard Chipboard
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
30,0 mm
Sandpaper with Silicon Carbide Abrasive
Shape
Disc
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
Grit
60
32,0 mm
32,0
Height
3,0
Variations
Delivery details: DREMEL® EZ SpeedClic: Sanding Discs (SC411)
Product box length, 1.6 cm
Product box height, 10 cm
Product box width, 5 cm
Gross weight, 0,01 kg
2615S411JA
8710364060917
