Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Sanding
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: sanding mandrel & sanding bands (SC407) 3 pieces
Bestseller
Sanding
Bestseller
Handy EZ speedclic mandrel for fast changing of 13mm sanding bands
  • The patented EZ Drum™ system making accessory changes 5X faster than using a standard mandrel
  • Allows for flat sanding and edge sanding
  • Compatible with all Dremel rotary tools
9.4 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Softwood
Hardwood
Soft Metal
Gold
Copper
Silver
Plastic
What can you do with it?
Sanding bands will generally remove finish and material (wood or other soft material). These bands are also used for (rough) shaping and smoothing or rust removal from metal. If you want to remove just finish, consider something less aggressive like a flap wheel (no. 502 or 504), or a buff like the no. 511S/512S.
How to use?
The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel.The physical appearance of the band indicates what grit it is, the larger the bumps the lower the grit.
Sanding bands are available in 120 and 60 grit. The lower the grit, the more material is removed.
Use the sides of the bands to do the sanding.
Sanding bands will wear out and are replaceable by loosening the screw on the top of the drum or using the DREMEL exclusive EZ Speedclic sanding drum, for even faster band replacement.
Materials to use on
These bands can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 10-35000 Softwood 10-35000 Aluminium 35000 Brass 35000 Ceramic 10-35000 Copper 25-35000 Plastic 10-20000 Stone 10-35000 Shell 10-35000 Steel 35000
Shank diameter
3.2 mm
Working diameter
13.0 mm
Accessory length
36.0 mm
Grit
60 / 120
13.0 mm
13.0
Height
32.0
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364060948
2615S407JA
Dremel accessory SC407 EZ SpeedClic: sanding mandrel & sanding bands
Delivery details
  • 1 EZ SpeedClic Sanding Mandrel
  • 1 Sanding Band 13 mm grit 60 (408)
  • 1 Sanding Band 13 mm grit 120 (432)
  • Product box length, 2.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
  • Gross weight, 0.02 kg
9.4 GBP
