Sanding EZ SpeedClic accessories
Dremel (SC407)
DREMEL® EZ SpeedClic: sanding mandrel & sanding bands
DREMEL® EZ SpeedClic: sanding mandrel & sanding bands DREMEL® EZ SpeedClic: sanding mandrel & sanding bands DREMEL® EZ SpeedClic: sanding mandrel & sanding bands
Handy EZ speedclic mandrel for fast changing of 13mm sanding bands
£8.00* RRP incl. VAT
What can you do with it?
Sanding bands will generally remove finish and material (wood or other soft material). These bands are also used for (rough) shaping and smoothing or rust removal from metal. If you want to remove just finish, consider something less aggressive like a flap wheel (no. 502 or 504), or a buff like the no. 511S/512S.
How to use?
The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel.The physical appearance of the band indicates what grit it is, the larger the bumps the lower the grit.
Sanding bands are available in 120 and 60 grit. The lower the grit, the more material is removed.
Use the sides of the bands to do the sanding.
Sanding bands will wear out and are replaceable by loosening the screw on the top of the drum or using the DREMEL exclusive EZ Speedclic sanding drum, for even faster band replacement.
Materials to use on
These bands can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel.
Can shape rubber surfaces
Recommended speed
Hardwood 10-35000
Softwood 10-35000
Aluminium 35000
Brass 35000
Ceramic 10-35000
Copper 25-35000
Plastic 10-20000
Stone 10-35000
Shell 10-35000
Steel 35000
Example of usage
Technical details for DREMEL® EZ SpeedClic: sanding mandrel & sanding bands (SC407)
  • Softwood Softwood
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Gold Gold
  • Aluminium Aluminium
  • Copper Copper
  • Silver Silver
  • Plastic Plastic
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
13,0 mm
Accessory length
36,0 mm
Grit
60 / 120
13,0 mm
13,0
Height
32,0
Variations
Delivery details: DREMEL® EZ SpeedClic: sanding mandrel & sanding bands (SC407)
1 EZ SpeedClic Sanding Mandrel
1 Sanding Band 13 mm grit 60 (408)
1 Sanding Band 13 mm grit 120 (432)
Product box length, 2.3 cm
Product box height, 10 cm
Product box width, 5 cm
Gross weight, 0,02 kg
2615S407JA
8710364060948
