Cutting
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Thin Cutting Wheels. (SC409) 5 pieces
Cutting
Extra thin cutting wheel. For making cuts in sheet metal and aluminium
  • Designed with the patented EZ Speedclic™ system making accessory changes 6X faster than using a standard mandrel.
  • 2X more cuts compared
  • Ideal for thin-kerf cuts in a variety of materials including hard metals like steel, metal pipes or sheet metal
See all variations
16 GBP
Metal pipes
Sheet Metal
Drywall/Plasterboard
Aerated Concrete
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
For slicing and cutting metal including hardened steel. Ideal for cutting, grooving and trimming all kinds of metal. Cut-off wheels make it easy to cut bolts or screws or make slots in rusted or stripped bolts and screws for removal with a screwdriver. Reinforced with fiberglass for increased durability. The SC409 wheels have a thickness of just 0.75 mm for even thinner cuts.
How to use?
The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately).
Cutting wheels only work on their edge.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron or even hardened steel.
Recommended speed
Aluminium 35000 Brass 35000 Copper 35000 Steel 35000
Working diameter
Package contents
Price
2615S409JB
38.0 mm
5 pieces
£15.50*
  • Extra thin cutting wheel. For making cuts in sheet metal and aluminium
2615S406JC
38.0 mm
2 pieces
£19.00*
DREMEL® EZ SpeedClic: Starter Set. (SC406) 2 pieces
  • SC Mandrel and 2 Metal Cutting Wheels. For cuts in e.g. hardened steel
2615S456JC
38.0 mm
5 pieces
£14.50*
DREMEL® EZ SpeedClic: Metal Cutting Wheels 5-Pack. (SC456) 5 pieces
  • Reinforced for durability, make cuts in e.g. hardened steel
2615S456JD
38.0 mm
12 pieces
£21.50*
DREMEL® EZ SpeedClic: Metal Cutting Wheels 12-Pack. (SC456B) 12 pieces
Shank diameter
3.2 mm
Working diameter
38.0 mm
Max working depth
14.0 mm
Fiberglass reinforced with Aluminum Oxide Abrasive
Shape
Wheel
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
Maximum RPM
35,000 1/min
5
5
Suitable Dremel devices
Retired Products
Multi-Tools
8710364042869
2615S409JB
Dremel accessory SC409_EZ SpeedClic: Thin Cutting Wheel
Delivery details
  • The fiberglass reinforced cutting wheels are just 0,75 mm thick. They are perfect for precise cutting in all sorts of metals. Quick, Easy, Keyless.
  • Product box length, 3.6 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
16 GBP
