Cutting EZ SpeedClic accessories
Dremel (SC409)
DREMEL® EZ SpeedClic: Thin Cutting Wheels.
DREMEL® EZ SpeedClic: Thin Cutting Wheels. DREMEL® EZ SpeedClic: Thin Cutting Wheels. DREMEL® EZ SpeedClic: Thin Cutting Wheels.
Extra thin cutting wheel. For making cuts in sheet metal and aluminium
£13.40* RRP incl. VAT
What can you do with it?
For slicing and cutting metal including hardened steel. Ideal for cutting, grooving and trimming all kinds of metal. Cut-off wheels make it easy to cut bolts or screws or make slots in rusted or stripped bolts and screws for removal with a screwdriver. Reinforced with fiberglass for increased durability. The SC409 wheels have a thickness of just 0.75 mm for even thinner cuts.
How to use?
The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately).
Cutting wheels only work on their edge.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron or even hardened steel.
Recommended speed
Aluminium 35000
Brass 35000
Copper 35000
Steel 35000
Example of usage
Technical details for DREMEL® EZ SpeedClic: Thin Cutting Wheels. (SC409)
  • Metal pipes Metal pipes
  • Sheet Metal Sheet Metal
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
Max working depth
14,0 mm
Fiberglass reinforced with Aluminum Oxide Abrasive
Shape
Wheel
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
Maximum RPM
Variations
Delivery details: DREMEL® EZ SpeedClic: Thin Cutting Wheels. (SC409)
The fiberglass reinforced cutting wheels are just 0,75 mm thick. They are perfect for precise cutting in all sorts of metals. Quick, Easy, Keyless.
Product box length, 3.6 cm
Product box height, 10 cm
Product box width, 5 cm
2615S409JB
8710364042869
Recommended products:
EZ SpeedClic Cutting Accessory Set
£28.00* RRP incl. VAT
