Cutting
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Wood Cutting Wheel. (SC544)
Cutting
With carbide coating for cutting wood and laminate (Not metal)
  • Designed with the patented EZ Speedclic™ system making accessory changes 6X faster than using a standard mandrel.
  • Cuts wood fast with little effort
  • Easy to assemble
See all variations
27 GBP
Sandwich material
Veneered woods
Softwood
Hardwood
Plywood
Laminates
Chipboard
Fiberboard
What can you do with it?
Wood Cutting Wheels are both carbide cutting wheels for slicing, cutting and shaping on woods and laminates. Ideal for short cuts in wooden floors to make room for e.g. heating pipes or electronics or model making. The carbide coating makes this wheel very durable.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately).
Cutting wheels only work on their edge.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different wood types, like chipboard, hardwood, softwood, laminate, fiberboard, or even on plastics and laminates. Do not use them on metals.
Recommended speed
Hardwood 20.000-35.000 RPM Softwood 20.000-35.000 RPM Plastic 10.000-15.000 RPM
Working diameter
Package contents
Price
2615S544JB
38.0 mm
1 piece
£26.50*
  • With carbide coating for cutting wood and laminate (Not metal)
2615S476JB
38.0 mm
5 pieces
£14.50*
DREMEL® EZ SpeedClic: Plastic Cutting Wheels. (SC476) 5 pieces
  • For making straight cuts and slots in plastics
2615S456JD
38.0 mm
12 pieces
£21.50*
DREMEL® EZ SpeedClic: Metal Cutting Wheels 12-Pack. (SC456B) 12 pieces
  • Reinforced for durability, make cuts in e.g. hardened steel
2615S456JC
38.0 mm
5 pieces
£14.50*
DREMEL® EZ SpeedClic: Metal Cutting Wheels 5-Pack. (SC456) 5 pieces
Shank diameter
3.2 mm
Working diameter
38.0 mm
Max working depth
14.0 mm
Steel with Tungsten Carbide Abrasive
Shape
Wheel
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
38.0 mm
Maximum RPM
35,000 1/min
38.0 mm
Height
1.0 mm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364042876
2615S544JB
Dremel accessory  EZ SpeedClic: Wood Cutting Wheel. SC544_, With carbide coating for cutting wood and laminate (Not metal)
Delivery details
  • Product box length, 3.6 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
27 GBP
