Cutting
DREMEL® EZ SpeedClic: Wood Cutting Wheel. (SC544)
DREMEL® EZ SpeedClic: Wood Cutting Wheel. DREMEL® EZ SpeedClic: Wood Cutting Wheel.
With carbide coating for cutting wood and laminate (Not metal)
£20.00* RRP incl. VAT
What can you do with it?
Wood Cutting Wheels are both carbide cutting wheels for slicing, cutting and shaping on woods and laminates. Ideal for short cuts in wooden floors to make room for e.g. heating pipes or electronics or model making. The carbide coating makes this wheel very durable.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE
Cutting wheels only work on their edge.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different wood types, like chipboard, hardwood, softwood, laminate, fiberboard, or even on plastics and laminates. Do not use them on metals.
Recommended speed
Hardwood 20.000-35.000 RPM Softwood 20.000-35.000 RPM Plastic 10.000-15.000 RPM
Example of usage
Technical details for DREMEL® EZ SpeedClic: Wood Cutting Wheel. (SC544)
  • Sandwich material Sandwich material
  • Veneered woods Veneered woods
  • Softwood Softwood
  • Hardwood Hardwood
  • Plywood Plywood
  • Laminates Laminates
  • Chipboard Chipboard
  • Fiberboard Fiberboard
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
Max working depth
14,0 mm
Maximum RPM
Height
1,0 mm
Package Contents
1 piece
Variations
Delivery details: DREMEL® EZ SpeedClic: Wood Cutting Wheel. (SC544)
Product box length, 3.6 cm
Product box height, 10 cm
Product box width, 5 cm
2615S544JB
8710364042876
