DREMEL® Glass Drilling Bit (663)
RRP incl. VAT
Drilling
Drilling
Biggest glass drilling bit to be used on straight or curved material
  • Drill holes in both flat and contoured glass
  • Diamond-impregnated cutting bit for long life
  • Diamond grit around the circumference of the bit allows it to rasp a larger hole if needed
  • Holes on the side of the bit allow the removal of material
  • Ideal for decorative projects including glass blocks or bottles
£26.50*
Glass
What can you do with it?
Ideal for drilling holes in both flat and contoured surfaces like glass or ceramic wall. Diamond grit is a full 360-degrees around the circumference of the bit which allows it to be used in a rasping action to enlarge a hole if needed. Holes on the side of the bit allow the removal of material. Ideal for decorative projects including glass blocks or bottles.
How to use?
When cutting a hole, ensure your work piece is well secured and do not apply excessive pressure to avoid cracking the glass. Apply cooling liquid or water to the material. Hold your tool at a 45 degree angle to go into the material. Then gradually lift your tool up to make a 90 degree drill. Apply drops of water / cooling liquid to the work piece for a clean drill operation. You can take the accessory out of the material to apply water or cooling liquid. Use with cordless tools only.
Materials to use on
Suitable for use on glass, ceramic wall tile, glass block, glass bottles, jewelry - flat or contoured surfaces.
Recommended speed
10.000-15.000 RPM
Shank diameter
Working length
10,0 mm
Accessory length
44,0 mm
Carbon Steel with Diamond Coating
Mandrel use
No Mandrel Needed
6,0 mm
6,0 mm
Height
45,0 mm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364080397
26150663JB
Dremel accessory  663  Glass Drilling Bit
Delivery details
  • The Dremel Glass Drilling Bit 663 is ideal for cutting holes in glass. You can drill perfect 6.4mm diameter holes. To be used with Dremel Cordless tools.
  • Product box length, 3.6 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
