Corded Tools
DREMEL® Glue Gun 910 (910-3)
Compact glue gun – For intricate and quick gluing in all light DIY jobs
Drip control prevents dripping glue onto the project supported with precision tip for intricate gluing
The T-handle allows optimal tool balance for easy and comfortable operation
Apply glue on various materials such as ceramics, wood, plastics, glass, etc.
£17.00*
RRP incl. VAT
The Dremel 910 is a high temperature (165 °C) glue gun with a drip-controlled precision tip. Because of its compact size and good ergonomics (T-handle, stable base, extendable stand) it is ideal for quick light DIY jobs around the house, such as gluing ceramics, wood, plastics, glass, etc.
Example of usage
Technical details for DREMEL® Glue Gun 910 (910-3)
Technical specifications
Voltage
Weight
0,24 kg
14 cm
3.7 cm
Depth
15 cm
High temperature
165 °C
Glue stick diameter
7 mm
Precision tip
Dual temperature
Removable cord
Drip control
Delivery details: DREMEL® Glue Gun 910 (910-3)
Dremel Glue Gun 910
3x Dremel 7 mm Multipurpose High Temp Glue Sticks
Instruction manual
Product box length, 16.5 cm
Product box height, 26 cm
Product box width, 6.2 cm
Gross weight, 0,47 kg
F0130910JB
8710364052356
8710364052356
