Corded Tools
DREMEL® Glue Gun 930 (930-18 Hobby)
Dual temperature glue gun – Bring your creativity to the next level with colourful and precise gluing
Included colour sticks allow you to go far beyond from simple gluing and lets you get creative in decoration, ornament making, jewellery design and more
Apply glue on various materials disregarding the heat-sensibility thanks to dual temperature setting combined with high and low temperature glue sticks
Drip control prevents dripping glue onto the project supported with precision tip for intricate gluing
The T-handle allows optimal tool balance for easy and comfortable operation
£20.00*
RRP incl. VAT
The Dremel 930 is a dual-temperature glue gun. Perfect for decorating both conventional and heat sensitive materials. The included transparent and coloured glue sticks provide you a fully creative crafting experience. From light gluing jobs to ornament sculpting, precise decorating of jars to mold making and embossing.
Example of usage
Technical details for DREMEL® Glue Gun 930 (930-18 Hobby)
Technical specifications
Voltage
Weight
0,20 kg
14 cm
Depth
Battery technology
Dual temperature
105 / 165 °C
Glue stick diameter
7 mm
Precision tip
Dual temperature
Removable cord
Drip control
Delivery details: DREMEL® Glue Gun 930 (930-18 Hobby)
930 Glue Gun
3x Dremel 7 mm Multipurpose Low Temp Glue Sticks
3x Dremel 7 mm Multipurpose High Temp Glue Sticks
12 x Dremel 7 mm Colour Sticks
Instruction manual
Product box length, 16 cm
Product box height, 26.3 cm
Product box width, 7.3 cm
Gross weight, 0,56 kg
F0130930JB
8710364052394
8710364052394
