Corded Tools
DREMEL® Glue Gun 940 (940-3)
High temperature glue gun – For all indoor and outdoor DIY applications
Removable cord allows to use the glue gun anywhere
Drip control prevents dripping glue onto the project supported with precision tip for intricate gluing
The T-handle allows optimal tool balance for easy and comfortable operation
Apply glue on various materials such as ceramics, wood, plastics, glass, etc.
£34.00*
RRP incl. VAT
The Dremel 940 is a high temperature (195 °C) glue gun with a drip-controlled exchangeable tip. With its removable cord the 940 can be used at any place without available power. Because of its good ergonomics (on/off switch, T-handle, stable base, extendable kickstand) and replaceable tip it is ideal for light DIY jobs around the house and outdoors, such as repairing furniture, gluing wood, ceramics, etc.
Example of usage
Technical details for DREMEL® Glue Gun 940 (940-3)
Technical specifications
Voltage
Weight
0,30 kg
20 cm
Depth
20 cm
Battery technology
High temperature
195 °C
Glue stick diameter
11 mm
Precision tip
Dual temperature
Removable cord
Drip control
Delivery details: DREMEL® Glue Gun 940 (940-3)
Dremel Glue Gun 940
3x Dremel 11 mm Multipurpose High Temp Glue Sticks
Instruction manual
Product box length, 20.2 cm
Product box height, 26.4 cm
Product box width, 6.1 cm
Gross weight, 0,65 kg
F0130940JB
8710364052417
8710364052417
