Glue Guns
DREMEL® Glue Gun 940 (940-3)
Glue Guns
High temperature glue gun – For all indoor and outdoor DIY applications
- Removable cord allows to use the glue gun anywhere
- Drip control prevents dripping glue onto the project supported with precision tip for intricate gluing
- The T-handle allows optimal tool balance for easy and comfortable operation
35 GBP
The Dremel 940 is a high temperature (195 °C) glue gun with a drip-controlled exchangeable tip. With its removable cord the 940 can be used at any place without available power. Because of its good ergonomics (on/off switch, T-handle, stable base, extendable kickstand) and replaceable tip it is ideal for light DIY jobs around the house and outdoors, such as repairing furniture, gluing wood, ceramics, etc.
Voltage
100 - 230 V
Weight
0.30 kg
20 cm
Depth
20 cm
High temperature
195 °C
Glue stick diameter
11 mm
Precision tip
Drip control
8710364052417
F0130940JB
User Manuals
Order numberF0130940JB
EAN Code8710364052417
Delivery details- Dremel Glue Gun 940
- 3x Dremel 11 mm Multipurpose High Temp Glue Sticks
- Instruction manual
- Product box length, 20.2 cm
- Product box height, 26.4 cm
- Product box width, 6.1 cm
- Gross weight, 0.65 kg
35 GBP
